AHAdam Hodge17/05/2011
Hello All,
I have some macros that have been programed in VBA using Excel 2003/2007. Since our company has switched to 64 bit SolidWorks most of them don't work anymore. I have checked the references with in the VBA area and ensured that all of them are active and have the correct path.
Where I am running into problems is when I go to start a session of SolidWorks VIA the API from Excel, I get a
Run Time Error "429"
ActiveX component can't create object
under the debug it takes me to the line
Normally this is an indication that the reference library isnt loading correctly, or it is missing something.
Has there been a change from the 32 bit call to the 64 bit call? if so, what is the new call that I need to use? What else has changed?
Not sure if I will need to have 2 versions of the macros, one for 64 bit and one for 32 bit. If I do, any possible way for me to detect the system type from Excel and open the appropriate version?
Thanks in advance,
Adam
