Can I import a water tight group of IGES surfaces and create a solid? But the trick I want is to not lose the surfaces that make up one face of the object. I don't want knit the surfaces together. I want them to remain as split surfaces. Is there anyway to do this?
Can you explain the purpose of this? There may be alternative solutions.
Could you create a zero-offset surface for later use, then knit and solidify ... or delete a face and use the Filled Surface tool to create the solid?
