Sheet 2 format is not linking the properties from default view
Question asked by Dalan Chan on May 13, 2011
Latest reply on May 13, 2011 by Dan Miel
I am created a sheet 2 format and attached it to the drawing template.  Everything works great, except that it does not take the properties from the initial model in sheet 1. When I create the 2nd sheet, the title block shows up empty.  If I go to edit sheet I see the properties that are set up.  If I add a new model on sheet 2, the title block fills out.
I would like all the sheets after the first sheet to have the same properties in the title block automatically fill out based on sheet 1 (initial default model).
Can anyone help?
Thanks.
