I haven't played much with created coordinate systems, But I believe you need to do is to edit the part in the context of the assembly 9have the assembly open, right click on the part, and select edit part) all of the rest of the assembly will be transparent, but will be selectable for defining the features of the part.
this will make an external reference to the assembly file, which is something to be careful about - especially with parts that will be used in other assemblies, as a change in the first assembly can affect other assemblies that use the part.
Jeremy,
That is what I ended up doing. I opened the part through the edit mode and select the assembly origin as the coordinate point of reference. When I do this the X-axis is on the correct axis but the wrong direction which is easy to fix, just reverse the orientation. But the Z-axis is on the reference Y-axis and vice versa. I was able to get it corrrect by selecting an edge for the Z-Axis and then reversing the orientation. Man it would be much easier if i could just pick an existing coordinate system instead of an origin. Thanks guys and thank you for the welcome. I'll check out the forum guidlines.
On a side note is there a best practice for setting up a global coordinate system? I'm familiar with the risks of using refernce geometry for mates. One of the issues I run into is I have to use models from customers and they already have an assembly origion, so I deal with refernce coordinate systems all over the place.
Jared
How about submitting an Enhancement Request
I am not sure quite what you are doing, but you may be making this harder than it needs to be. If you make the part origin the same as the assembly origin, when you go to insert the part, just click on the green checkmark in the confirmation corner and the part will be 'fixed' in the assembly, with origins and planes coincident but no mates overhead. Also, you can drag the part out of Windows explorer and drop it on the assembly origin and get the same effect. If that isn't feasible and you need an in context coordinate system, I would try putting in a plane in the part file coincident with the assembly origin, sketch two lines on this plane to define your x and y axes, and attach a coordinate system to the sketch lines. Then you can mate the coordinate system to the origin, and this gives you the option to align axes as well.
Welcome to SW forums Jared
You can draw an axis or sketch (line) entity or take some edge reference to define the axis orientation.
Also read this post for your future reference: Forum Posting
