I have a number of list coming though a linked server from a MDB file set to "Periodic refresch every' 5 minutes. It does not update the list for use by the cards. The test button works. If I change the query and save, the cards get the updated information. How do I get Periodic refresh to work? I am testing using the EPDM admin account.
Hi Ron,
SQL lists are updated by the Enterprise PDM database server service - so if the periodic refresh is not working, then its likely the service that is not running as it should. I'd recommend going through the troubleshooting steps in KB solution S-08226. If it still is not working, contact your VAR for help.
-Tor, EPDM support
