I've been looking at Dispatch to convert SLDRW to PDF once it entered the approved state . I know EPDM has the TASK function to do this, but it is limited in a sense that it doesn't let me choose the file data card variable to direct the location where i want to save it too.
first question is ..how do you convert pdf using dispatch?
second questions is
i want to be able to save the PDF in a location, depending on the value of a file data card variable called modelNumber...for example
if modelNumber is 311DBS , the converted pdf should go in a folder named 311DBS.
The actual folder names are already created.
any help will be appreciated.
thank you
Hi Earl,
Actually, this would be easier if you modified the script in the task.
Reference:
Solution S-052490
Best Regards,
Joy
