I apologize if this question has an answer, I couldn't find it while searching.
Okay, so. I sometimes get a project to import several DWG Autodesk files from 2D and convert them to 3D. I have all my person default templates setup and working beautifully (by the way, if you want a great way to share common templates over many computers not on the same net, use dropbox.com) .
But, I'm at a loss as to what defualt part template the import process uses. I would like to make some changes to streamline the starting of the model.
The question is; where are these files, and what are the names?
Carter
No, you can only set one template up in the properties.
But what you can do is callup the othere template in a session of
Solidworks and do a save as copy. Then this new file will have the settings of this template.
