I'm trying to convert this part into SM but having a hard time. I was able to create the part from scratch in SM as you can see in Import1 Body and in the second attachment. The reason I want to convert the solid part is because I would like to use the Solid Body to calculate the internal volume of the part. Also I want to have the option of modifying the solid body and have the SM part update and still have the option of calculating the volume using the updated solid.
Wow, can't believe I didn't bother to check the flattened part. Sorry about that, a quick change of one of the bends eliminates the interference.
