HI,
Is there or what is the best way to show decals in the bom. basically i have a products that i need to attached decals which need to be shown in the bom also. The images in the decals have codes which can be identified. Any help would be great.
Dan.
Hi Dan,
Welcome to the forum.
Decals in and of themselves alone cannot be listed in the BOM parametrically.
The best way I can think of to do this if you want it parametrically (automatic)
is to insert this decal into a part with no geometry (just places and axis). Save
it out as the file name you want represented in the BOM along with filling out
the custom properties. Then insert this part into your assembly and it will show up
in the assembly drawing BOM.
If you don't care about it being parametric then just add a line item in the BOM
by RCing on one of the lines and select insert a row. Then just type in the decal
info. Hope this helps you. Good luck.
