I am going to try and describe this the best I can. I have researched on the
forum for what I am trying to do in weld beads.
I have figured out how to create a weld bead between 2 components. But what I want to know
is there a way to control the shape and size of the bead similar to if you were to to a swept feature
along a guide curve with different sketches. Or like what we are able to do in the chamfer command in specifying
the lengths of each cross sectional side.
What I have is a circulat rod that is chamfered on the mating end and I want a weld bead around when it that fills in the chamfer.
Then when it mates up to a rectangulat plate doesn't extend past the flat edge surfaces of the plate on the vertical sides.
If I had access to snagit I would most definately show you a pic of what I have.
instead of snagit just select print screen from keyboard or alt+print screen.
then open paint, paste (ctrl+v)
save as jpeg or png
