I use Get Components in Each BOM Table Row (VBA) but appear an run-time error in vPtArr = swBOMTableAnn.GetComponents(J) line , any idea.
In SW 2010 work ok, i modify this macro for add instance name in BOM , for each part or row.
Hi Filipe, thanks for all . I try this (see below) macro in oher machine with SP0 and work ok.
This example shows how to get the components in each row in a BOM table annotation.
' Preconditions: Drawing document is open that contains
' one or more bill of materials tables.
' Postconditions: None
Option Explicit
Sub ProcessTableAnn(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swTableAnn As SldWorks.TableAnnotation)
Dim nNumRow As Long
Dim J As Long
Dim I As Long
Debug.Print " Table Title " & swTableAnn.Title
nNumRow = swTableAnn.RowCount
Dim swBOMTableAnn As BomTableAnnotation
Set swBOMTableAnn = swTableAnn
For J = 0 To nNumRow - 1
Debug.Print " Row Number " & J & " Component Count : " & swBOMTableAnn.GetComponentsCount(J)
Dim vPtArr As Variant
Dim swComp As Object
Dim pt As Object
If (Not IsEmpty(vPtArr)) Then
For I = 0 To UBound(vPtArr)
Set pt = vPtArr(I)
Set swComp = pt
If Not swComp Is Nothing Then
Debug.Print " Component Name :" & swComp.Name2 & " Configuration Name : " & swComp.ReferencedConfiguration
Else
Debug.Print " Could not get component."
Next
Next J
Sub ProcessBomFeature(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swBomFeat As SldWorks.BomFeature)
Dim swFeat As SldWorks.Feature
Dim vTableArr As Variant
Dim vTable As Variant
Dim swTable As SldWorks.TableAnnotation
Set swFeat = swBomFeat.GetFeature
vTableArr = swBomFeat.GetTableAnnotations
For Each vTable In vTableArr
Set swTable = vTable
ProcessTableAnn swApp, swModel, swTable
Next vTable
Dim swSheet As SldWorks.Sheet
Dim swBomFeat As SldWorks.BomFeature
Dim nNumSheet As Long
Dim nRetval As Long
Dim I As Long
Dim bRet As Boolean
Set swModel = swApp.ActiveDoc
Set swDraw = swModel
Set swFeat = swModel.FirstFeature
Do While Not swFeat Is Nothing
If "BomFeat" = swFeat.GetTypeName Then
Debug.Print "******************************"
Debug.Print "Feature Name :- " & swFeat.Name
Set swBomFeat = swFeat.GetSpecificFeature2
ProcessBomFeature swApp, swModel, swBomFeat
Set swFeat = swFeat.GetNextFeature
Loop
Hi Jorge, it would help if we could see a snippet of the code.
Cheers
