I am using SW2011 SP3.
I added a custom property to the cutlist properties in a weldment part. The added property is NAME and the value contains text. I began creating the drawing of the weldment and inserted the cutlist table and added the column for the additional NAME property. All worked as it should.
The text strings for the NAME property of each body are very similar. This made me notice in the drawing table that I had some spacing and capitalization inconsistancies between the bodies. I returned to the part file and edited the cutlist NAME property. I was able to correct the spacing issues, but I cannot get the change in text case to "stick". By that I mean I can edit the property text and ether tab or hit enter and the Evaluated Value field updates to match. But if I switch to a different body or close the dialog and reopen, the change has disappeared. I have tried a restart of SW.
Criticality is low, but it does have an "annoyance" factor.
Any suggestions are greatly appreciated.
Daen
Try editing the property into something else first, and then changing it back into the original version with the updated capitalization.
