Bug in configuration properties???
Question asked by Shawn Casebolt on Apr 25, 2011
Latest reply on Apr 25, 2011 by Deepak Gupta
I cant believe I have not seen a post on this before, but it is wreaking big havoc on us here.  Anyones help would be appreciated.  Here is the issue.
When you create a new configuration, In the configuration properties, under the  "Advanced options".....you have the option to check the box "suppress features".  When checked, any new features created later will not be active in that configuration.
The problem is, that the box seems to seemingly uncheck itself at random.  This morning I went thru and verified that every single configuration had this box checked.  I added a cut feature to one of the configs, and BAM there it is in some of the others, and if I go to properties, that box is unchecked.
Any ideas what is causing this?  Is there a setting somewhere?  Our models are getting to the 15+ configuration range, so going in and fixing them each time you add a new feature is becoming impractile.  Lastly, this is not limited to cut features, normal extrudes as well.
