Can someone please tell me what the forth Icon on the tree means? It looks like an assembly icon but a little different. Its the one with the name "Reader Bracket with Gear"
Mukesh,
That means a flexible assembly. Basically what this allows you to do is mate a component
from a subassembly at the upper level assembly level. I have run into this when my company
wants a component at a sub assembly level for inventory reasons, but is does not get installed
until the final assembly level.
That's a flexible sub-assembly. When you insert assemblies into an assembly it (by default) treats it as a rigid group, to save on mate rebuild times. You can make it flexible though, and then it will calculate all the mates within that sub-assembly even at the higher assembly level.
http://help.solidworks.com/2011/English/solidworks/sldworks/legacyhelp/sldworks/assem_1/flexible_sub-assemblies.htm
