I am trying to add decals to a part, but when I do they show straight through to the other side. How do I prevent this?
hmm. Have you selected just the face of the part you want to apply the decal to or the entire part? You should just select the face you want to apply it to.
Rob, is there a way that I can do that in an assembly? When I pick a face, the model jumps int Edit-in-Assembly mode, and I can only pick a face on one part.
The message I get is:
"Decals cannot be added or edited other than on the component in Edit Part or Edit Subassembly mode."
Is there a way to avoid the problem of having the image showing on both sides of the parts and still work in an assembly?
