I am applying a decal in label mode to a section of an elliptical structure. But when I do so the decal application does not come out right. The default mode that comes up when you select the surface is cylindrical which looks ok but the graphic does not come through with the exact correct mapping dimensions. If I change it to label mode then the surface is cut at one of the widest sections of the ellipse. This does not seem like the intended behavior of a proper decal in the label mode.
Any suggestions? Is this a reported bug that anyone has reported / seen?
Jonathan
Jonathan,
Can you show an image? Applying to a extruded elliptical surface right? if so, use the cylinderical map and just uncheck the ratio lock and correct (by eye) the aspect ratio with the sizing widget in the viewport. Recheck the lock aspect ratio and scale and move to suit.
That said, Label should work - not sure why.
Regards
Mark
