Hi. I've read some of the forum posts regarding a heat source inside an enclosed box.
https://forum.solidworks.com/message/186708#186708
If someone could please tell me how to set up the flow simulation (see pics) and boundary conditions (see pics) that would be great.
I don't know if I should enable gravity and radiation. They exist so I wanted to include them.
My heat source will be 5W and attached on the inside of the aluminum enclosure.
I'm trying to find:
how hot the enclosure gets at certain points on the enclosure.
how hot it gets inside the enclosure.
Lastly, when setting up the analysis I can choose radiation. Here I can specify a temperature..this is the outside temperature, right?
I'm hoping my pictures will make answering this post easy. Thanks.
Jake, I just posted two responses to that thread you referenced ( Best Approach to Simulation temperature inside a sealed enclosure with a high external ambiant ), check it out to see if it helps.
