Problem with new API Functionality
Question asked by Jim Sculley on Apr 12, 2011
Latest reply on Jan 24, 2014 by Daniel Do
The What's New for 2011 includes the following:
IEdmCmdNode
This  interface is provided in the EdmCmdData.mpoExtra member when you get a call to IEdmAddIn5.OnCmd for a change state operation.  Its purpose is to give the API programmer an opportunity to traverse the entire  assembly tree involved in the operation.
This  interface inherits from IDispatch.
Methods
Description
GetProperty
Returns a  property (such as a list of parent files or child files) of the file in  question.
The docs for GetProperty:
IEdmCmdNode::GetProperty
This  method returns a property of the file described by the EdmCmdData struct from which mpoExtra pointer the IEdmCmdNode interface  came.
Prototype
HRESULT  GetProperty( [in] enum EdmCmdNodeProp eProperty,
                      [in,optional] VARIANT oArg,
                     [out,retval] VARIANT  *poResult );
Arguments
Type
Description
eProperty
enum EdmCmdNodeProp
Argument  telling what kind of property you want to retrieve
oArg
VARIANT
Reserved  for future use. Must be empty.
poResult
VARIANT*
The  returned value of the property. The type of property depends of the  eProperty argument.
Return  Codes
Description
S_OK
The method  was successfully executed.
The allowed structure values:
EdmCmdNodeProp
These enum values are used as  parameter to IEdmCmdNode.GetProperty to tell which property to return.
Name
Value
Description
EdmCmdNode_IsTopNode
1
(Boolean) True if thw is a top  node
EdmCmdNode_ChildDocIDs
2
(SafeArray of integers) File IDs of  child files
EdmCmdNode_ParentDocIDs
3
(SafeArray of integers) File IDs of  parent files
I can call GetProperty passing in the IsTopNode value and the call succeeds, returning true or false.
If I try to call GetProperty using ChildDocIDs or ParentDocIDs the call fails with an ArgumentException (Message = "The method returned a COM Variant type that is not Interop compatible.").
Has anyone had success using this new functionality?
Jim S.
