I have same problem with PDMWorks 2007 SP1 (and SP0.0).
I contact my VAR (about 4 weeks ago) but I don't get any answers for now.
Another problem with PDMWorks 2007 SP1.0: If I made a pattern for a part with some configurations into assy, after reporting form PDM, the result is wrong for pattern components (is display other configurations instead of parent config.).
This is very very bad for as.
when i'm reporting an assembly and i select a configuration in which some components are suspended, the report ignore that and give me the complete list of components !!.
even it give a "quantity =1" on suspended components.
i don't figure out why they have programmed such a behavior.
if i want the complete BOM of an ssemblyin that particular configuration i've to export tio csv and remove manually all the suspended component !!!
and there isn't a sign in the report that component is suspended.
i found this very bad.
have you ever found this problem and have figured out a solution or workaround?
tia
