PCPaul Costales08/04/2011
I believe I have a handle on how the drawing templates and sheet formats work but there is one minor annoyance that I maybe could get rid of.
Our default Drawing template DRAWING.DRWDOT is just one sheet and has a lot of info in the title block linked to the Part properties.  I also made a SHEET2+.SLDDRT file in the templates directory that has a streamlined title block for Sheets 2 and beyond. As it is now if you want to add additional sheets, you click on "add sheet" and it brings up a dialog box where you select the SHEET2+.SLDDRT file and you are on your way.
Is there anyway to avoid having to select the SHEET2 format when adding new sheets with different sheet formats than Sheet 1?  The only way I am able to avoid choosing that file is if all of my sheets use the same format. Thanks.
