GKGordon Kistler06/04/2011
I'm trying to add a sensor in a part file so that a dimension doesn't go below a certain value. When I select Sensors/Add Sensor and then select Dimension as the Sensor Type, I can't figure out how to get the Properties box to populate. There are no dimensions in the graphics area to select. It seems this should be a simple thing to do but for some reason it doesn't seem to be working correctly. I'm using SW 2010, SP 4. Thanks in advance for the help.
