I have a gauge table that provides the K-factor for various combinations of material, thickness, bend radius, etc. I created a sheet metal part, select "Use gague table", and then selected the table from the pull-down menu. Below that in the Bend Allowance section I select "Gauge Table" from the pull-down menu. The box immediately below the pull-down just shows "Gauge Table Values". I would like to be able to verify in the model the actual K-factor value that is being pulled in from the table for that part. When I was just entering the K-factor directly in the part file it was (obviously) easy to see the value. Is there a way to verify the K-factor value now that I'm using the table?
Gordon, I do not believe that there is a way to verify that the correct K-factor is being used. I do know that if the gauge table is not written correctly, SW will give you an error message when it tries to pull the k-factor from the gauge table. I commented on the formatting of gauge tables in this thread https://forum.solidworks.com/thread/31522
Hopefully this thread will help you out. Chad
