Assigning a variable.
Question asked by Stephan Hess on Apr 6, 2011
Latest reply on Apr 6, 2011 by Jim Sculley
Can you assign a variable to a file without disaplaying the value for that variable on the data card?  For instance, if you were trying to set up transitions in your workflow with conditions, you might have a variable that could be set to "yes" or "no" and then further along in the workflow, conditions in a transition could allow the file to pass or not.  That "yes" or "no" value may not be something you would want shown on the data card.  It's only to make the workflow function.  I found that if you hide those fields on the card with control logic, it works, but I was wondering if there was a way to assign that value without it being on the card at all.
Thanks.
Stephan
