Hello
In an assembly I am having problems with how a sub assembly acts in the full assembly.
It is a fully defined sub assembly but yet it will rotate 90degrees out of postiion until I rebuild then
will rebuild correctly until I do something else in the assembly. for instance add another part to it, or, just rotate the assembly
to check, then it will rotate 90 degrees again.
thankyou
Mark
IDFI
Mark,
Try creating a brand new assembly and first bring in the main assembly
and then add this sub assembly. Does it do it then?
Did you create the main assembly from scratch on your own?
