Has anyone tried to have a cable carrier bracket mated to a base and the other bracket mounted to a slide and have the carrier links mated to each other and the brackets such that the base bracket is fixed and the bracket/links would travel with the slide?
SW does not have inverse kinetics so the chain will blowup when you try to move it. The best you can do is two configurations and that is hit and miss, most of the time it will blowup also.
