So learning from past experience I have waited to upgrade to SW 2011 until SP3. I do like the predefined decal illumination options that are in PhotoWorks(Matte, Constant, Plastic, etc.) Any chance someone could post a list of what the settings are for PV so I can obtain the same result as PhotoWorks?
I also do not get a good result when I use the image mask options. In the past when I want just white text I would use a jpeg with white text on black and then use the same image as a mask. Now what I get is washed out white text and the black area now goes to gray. PNG files do not look right also. They come over as shades of gray when they are supposed to just be white text.
Any help with this is appreciated.
Jonathan
I've attached a non interlaced png file for you to try. Check the "use file alpha channel" with this one.
To give the decal the setting you want like plastic, metal, etc you'll have to look at a preset appearance, medium gloss white plastic as and example and set your decal illumination settings to match those.
