Hi, i try and try to move a part on my path, i look many youtube tutorial and i look at SWX tutorial, all seems simply and easy but when i try to do the same exercise with my swx professional a fail all times ....
Here you find my last experiment, an here you can look how it fails ....
http://www.youtube.com/watch?v=JMoFJffarYA&feature=player_embedded
Could you help me to find the right way?
Luca,
First make sure your model is not fixed in the assembly. You can tell be if you
look in the feature manager you will see an (f) next to the component. If it is
RC on it then select "float". If this is the case now try it and see what happens.
