CAN'T FIND THE FASTENNER
Discussion created by Guest on Nov 23, 2006
From the SolidWorks Help files:
"To access SolidWorks Toolbox contents, you must install and add in the SolidWorks Toolbox and SolidWorks Toolbox Browser"
Look at Tools > Add-ins and make sure the Toolbox add-ins are checked.
Also make sure the path to the Toolbox location is correct, Tools > Options > System Options > Hole Wizard/Toolbox.
Regards,
Anna Wood
SW06 SP5 x64, WinXP x64
Dell Precision 380, Pentium D940, 4 Gigs RAM, FX3450
WD Raptors, 1 Gb network connection
www.auerprecision.com
on 2006 23 19:36 angle wrote:
> Thanks Anna Wood.
> But I still can't find the toolbox in the right side pane. It said that I haven't
> installed the toolbox, in fact , I did.
> In the menu of toolbox, there are only cam, bearing, steel.... ,but there is not bolt,
> what's wrong?
