i have an assembly drawing with 5 parts. im trying to edit the font of the bom thru doc properties. only one line item is changing. wtf?
I ran into this a while back....
Go to TOOLS>OPTIONS>DOCUMENT PROPERTIES>TABLES and uncheck the box on the front menu for "Use Template Settings". If this box is checked it will use what the settings were in the saved template used to created the BOM.
Its kind of quirky I admit. If it doesn't update the table as a whole automatically simply select the pan symbol in the upper corner (four arrows) and then click "use the document font" (the little folder button with the A in it) from the toolbar button twice to refresh the table (once to uncheck it and twice to recheck it.
To edit the font for a BOM go to Options > Document Properties > Tables > Bill of Materials.
