RSRobert Stemen29/03/2011
I'm having a problem opening some IGS files I just received. I have SW2010 Standard.
Here's what happens...
I open it and I get the "The default templates are not valid... ...do you want to continue with a blank template?"
I click "OK" and it opens but there is nothing showing. All the parts are listed in the assembly tree but each part is empty. It just shows a bunch of origins floating in space.
I have opened IGS files in the past and it has worked. I also opened a single part in IGS format that I received in this same lot and it also worked. Any ideas why the assembly IGS isn't working?
Robert
