How can I use a finished part on a mold assembly and allow for matrial shrinkage for my final mold drawing? I have inserted my finished part onto the assembly by combining the part. I now have to allow for shrinkage in some areas as it is a silicone mold. So in essense I need to remove material in the cavity in a few of the areas. I needd to do this without altering the finished part drawing.
One way to do this would be to not actually use your finished part in the mold assembly. Instead open up a new part and use Insert part to have your Finished part be the base part of your new file. Then you can apply shrinkage as needed to this new part and use it in your mold assembly. Down the road-if you make any changes to the base part -your mold geometry can be made to update as well.
