Hi everyone,
After recently getting my company to purchase solidworks and jumping into 2011 I've found a couple of little things in the UI bothering me as the last version I used back at university was 2008. I was wondering if there was a quick solution to my problem.
The issue involves the default displayed tabs in the command manager. Previously I found after performing a feature such as an extrusion, creating the sketch and finalising the feature itself the command manager would revert back to the features tab once the process was finished. Now I find it remains in the sketch tab after the feature has been finished. Is there a way to set the feature tab as the default so it will always revert back to features after completing the previous feature and associated sketch?
While not a major concern it is just an issue affecting the flow of working, having the switch back as I tend to work straight from the features tab more than I do the sketch tab.
Chris
Do your self a favour ... customize and use the S key and and keyboard shortcuts. They will improve your workflow no end, and the Command Manager will become a thing of the past. I''ve had mine disabled since shortly after the introduction of the S key function.
You could also try using the Mouse Gesture function.
