Dimensions in title
Discussion created by Guest on Sep 6, 2005
I am not sure if it is possible to parametrically reference a flat pattern dimension.
If the part is folded then the dimension changes.
This leaves 2 options
1 measure the dim and add the property manually to the part.
2 if the part is not in an assembly, insert a flat pattern view & use that to drive the BOM
Regards
Martin
