I have a problem. When I was start an analysis, I take "*.SL3 file is not found" error notification. If I convert to connection options (bonded) analysis can be run. But bonded connection is a wrong approach for my analysis. My analysis should be "no penetration". But if I use no penetration connection type, I take *.SL3 file is not found notification at right away.
I take Intel(r) Visual Fortran run-time errorpage after pres ok SL3 file is not found noticifaciton.
I' m using
SolidWorks 2010 SP4.0 Premium Simulation Professional,
Windows 7 64 bit
Intel I7 2,8 GHZ
16 GB RAM
Quadro FX3800
I have met the same problem. Does someone know how to solve it ?
Thank you.
