Why this happen in Some models with patterns and complex commands?
What is the reason behind this ?
Advance thanks for your views and advices ..
AD
AD
Expand the Feature Manager to show the Display Pane to see what states have been activated.
Right-click on the Display Pane and select Clear All Top Level Overrides.
If the above suggestions don't work, rollback (or suppress) certain features or patterns to see if the display returns to normal?
Ajay,
You have a topological error in your model. Go to Tools>Options>System Options>Performance. The first checkbox is for "verification on rebuild". Turn that on, then hit CTRL-Q. This will do a full force rebuild, and it will probably turn some of your features RED. Those need to be analysed for why they are bad (causing inverted faces).
Make sure to turn verification on rebuild back off after you get it all fixed. It very significantly increases rebuild time, so you don't want it on all the time.
Here is an example of me doing this on purpose: https://forum.solidworks.com/message/68019#68019
Ajay,
