I am sure that cylinder and beam do not interference
and program also avows it ,but I see interference (?)
outside cylinder wall.
DId I set something wrong.
Krzysztof,
When you have an object behind a relatively thin wall, SW often decides to show the object, even though it doesn't come through or up to the outer wall. It's one of those things that most of us just learn to live with, although I seem to remember that someone recently posted that a certain viewing or display mode would display correctly. Unfortunately, I don't remember what the mode was. You might try searching in the forums to see if you can find it. I think it might have been about parts showing up in drawings that should not have been seen.
Jerry Steiger
Krzysztof,
Jerry Steiger
