I'd like to make a derived sketch on another plane, but each time I try it's a mirror of what I want, so so one said
to make a plane 180 degrees from that plane and use the 180 degree plane, but that still gives the same
results. What is it I'm doing wrong or can a personal use a flip command of some kind.
Thank You
just select the sketch you want and do a convert entities.
