Hi Folks,
I'm trying to draw an ellipse with a geometric relation that I'm trying to keep...
- I have a 6x6mm square whose center is at the origin, so that the sides are perpendicularly 3mm away from the origin.
- Now I want to draw an ellipse with the following characteristics...
- The ellipse should be centered at the origin as well, just like the square.
- It should have a vertical width (minor axis??) of 8mm, 4mm each above and below the x-axis
- I want the ellipse to go through the corners of the square
How do I draw an ellipse in Solidworks knowing just this info? I don't know exactly how wide the ellipse is along the x-axis, which is what it looks like Solidworks needs. It's somewhere about 9.08mm, but more importantly, I want to go through corner of the square and then trim certain sections off.
Divya.
