We are trying figure a way to model a laser cut tube that will be bent.
We need a flat pattern and a bent configuration.
Here is the final shape of the tube and a detail of the cut out.
Does anybody have use this type of cut out before?
Have you been able to model it in SolidWorks?
Thanks for your help.
Martin
Was that model not created in SW?
Extrude the open tube section
Cut-extrude the side notch per "CUT OUT DETAIL.JPG" on both sides
Apply a Sketch Bend across the remaining portion of the tube
The Flatten tool should then work
