I have an imported part that was created in SolidEdge sheetmetal. I need to convert this part to sheetmetal in SWx so I can get a flat pattern DXF. When I do this, the conversion makes weird cuts in the bend reliefs.
Has anyone seen this or have a solution?
insert is good for thin-feature parts which are modeled with sheetmetal in mind.
also ideal for sheetmetal parts imported from other cad applications.
insert can add bend relief's if needed.
convert is an entirely different beast.
convert is primarily for solid blocks.
it's a one-button-do-it-all feature.
look at the difference in the dialog box for each.
look in help as well.
they are vastly different.
most parts created using convert will need tweaking by sheetmetal programmer to clean up gaps and relief's.
