Just happened today. I tried to pack-n-go a part and the SW did not response at all
Any idea what is wrong here
Thx.Chris
Thx.Chris
Try the Recursive R solution; If the first solution doesn't work, move onto the next level.
Re-start SolidWorks
Reboot the computer
Repair SolidWorks
Reinstall SolidWorks
Rant & Rave here
Remove SolidWorks
Run other programs till you discover they have similar or worse problems
Re-install SolidWorks
Return to being dissillusioned ... but productive
Rinse and Repeat
Regards.
I just seconds ago did a pack and go and it worked fine. Even added a prefix.
I am running 2010 SP 4.0
You might have run into the situation where you have more than one monitor and it's coming up on the "other" one.
The problem may be that the Pack and Go dialog does come up, but it is not visible to the user. When the dialog is up, no clicks respond in SolidWorks if Pack and Go was launched from the SolidWorks File menu. Windows Explorer is similarly locked out while the dialog is up. If the dialog is not visible to the user, it could appear to be a hang/freeze.
One known cause of this problem is a failure to reset the dialog if it was last positioned on a monitor that is no longer active. For example, move the Pack and Go dialog to monitor 2 and then disable monitor 2. This will reproduce the behavior. SPR 395583 has been reported to development to properly reset the dialog back to monitor 1. Please refer to the SolidWorks Knowledge Base to find the latest status of this SPR. Please contact your reseller in order to be added to the notification list so that you are informed when the issue is resolved.
To manually reset the position of this dialog, go into the Windows registry.
Start->Run->regedit.
Browse to HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2009\PDMWorks
Delete "CopyDesignDialog"
Use caution while working in the registry as changes to the registry can affect all programs on the computer including the operating system.
Or you may have to register the proper dll file per this discussion.
https://forum.solidworks.com/message/74777#74777
WT
WT
