Hi all - yes its friday!!
I have a question... I have configured the web server for EPDM and am trying to test it. When I attempt to login to the vault via the web interface it says the login operation failed.
I was slightly confused as I set up the authentication using AD but the vault doesnt have AD authentication set and just uses the DB authentication. Any ideas is appreciated thanks
Can you login as the "ADMIN" user? That is the only user that does not use any AD authentication. (Assuming you have AD authentication turned on.)
