I've recently started a new Designer position using SolidWorks 2010. I've been given a PC that had been used previously by another user. There are some major toolbar issues with this setup...
1. The View (heads-Up) toolbar is missing even though it's selected to be active...de-selecting it has no effect.
2. The Shortcut bar is empty no matter if I'm in a drawing, model, assm, etc. I can add icons, but like the way SW has them organized by default.
3. The Command Manager at the top has a lot of missing icons. For example, the Sketch tab is nearly empty
I've went to the Customize/Options tab and reset everything to defaults and it has no effect. I've done a little digging through the SolidWorks folder in the Program Files directory and couldn't find anything that I thought was a custom user file. I've also scanned the Registry to see if anything jumped out at me, but I didn't see a smoking gun.
So, basically I'm looking for help just getting everything back to defaults! Any help is much appreciated.
Jeremy Walser
