Ok, I have a box with heat source in it, in a larger box. I want to find the steady state temperature of the fluid (air) in the heat source box and the temperature of the fluide (air) in the outer box. I have not found a way to get the temps of the independent fluids.
Any ideas out there?
Thanks in advance.......
Noel,
Have you reviewed the Tutorial to calculate "Ch. 6 Heat Exchanger Efficiency" which establishes a fluid sub-domain to predict the temperature of two diferent and separate fluid streams?
