RJRob Jensen01/03/2011
Hello everyone.
I found this macro on the forum and it's "almost" exactly what i need.  The problem is I have 2 layers.
What I can't figure out is adding the code to turn off a layer.....for example
I have text on layer A and layer B.  I want a macro that will display layer A and turn off Layer B.  Then, if your run it again, it will display layer B and turn off layer A
Thanks....Rob
Dim swApp As Object
' Preconditions:
'          (1) Drawing document is open.
'          (2) Drawing document contains a layer named PROTO.
' Postconditions:
'          If PROTO layer is visible, then it becomes not visible.
'             - or -
'          If PROTO layer is not visible, then it becomes visible.
Option Explicit
    Dim swApp                       As SldWorks.SldWorks
    Dim swModel                     As SldWorks.ModelDoc2
    Dim swLayerMgr                  As SldWorks.LayerMgr
    Dim swLayer                     As SldWorks.Layer
    Set swModel = swApp.ActiveDoc
    Set swLayerMgr = swModel.GetLayerManager
    Set swLayer = swLayerMgr.GetLayer("PROTO")
    If swLayer.Visible = False Then
        ' Toggle layer on
        swLayer.Visible = True
        Debug.Assert True = swLayer.Visible
    Else
        ' Toggle layer off
        Debug.Assert False = swLayer.Visible
