I have seen various methods on this forum to roll a flat pattern. The edge flange unfold, cut pattern, then refold. the hem. the center point arc into edge flange... but what I am trying to find is a method a simple method that I once saw for solidworks 2007 where one could roll a flat shape into a cylinder. I am going to include a file that we have a bunch of flat stock already laser cut that I just would like to represent as a cylinder. we roll the seam weld this part. Can anyone suggest a simple method? maybe some sort of edge bend? its is 18guage metal and the part is rolled with a roughly 2" radius, so the tabbed cuts are on the top and bottom edges.
If you know the part size is okay & you have the rad you should be able to use a Sketch Bend.
Michael
