How do I get this cone to rip/ unfold from the extrude cut instead of the revolve gap set at 359*
The lines of the extrude should completely sever the cone, when I do I get an error.
PS i have SW 2008
PS i have SW 2008
I couldn’t get the "rip" command to work with lines on a face plane or on edge, however I found that if I make a 360* revolve then than draw a single line on the thin edge of the cone and extrude cut "thin line" it will allow me to insert bend to that edge but I can't get the line to follow a path to cut.
Reno what I think is when you do revolve (with 359 or less), it is the same thing when you're bending a flat sheet. There will some distance/gap in the edges/vertices if you do revolve vs you do an extrude cut.
Now looking at your issue, I'm not sure what exactly you looking for or what you trying to do. Can you please explain in more details about your requirements.
