1 Reply Latest reply on Feb 25, 2011 3:24 PM by Anthony Botting
    Static Thermal Simulation of Piping Runs
    Bill Markert
      I am starting to investigate the usability of simulation to structurally evaluate high pressure/temperature piping runs with SolidWorks Premium Simulation.
      Specific question at this point is how to fixture the end of a pipe/flange that provides for no translation or rotation of the end face while allowing for radial expansion due to temperature and pressure. I see how I could totally fix the end using "fixed" but I am confused as how the "on cylindrical face" can be used to achieve the desired result of fixing only the end face of the pipe or flange in this case.
        • Re: Static Thermal Simulation of Piping Runs
          Anthony Botting
          Hi Bill:
          You can install what is called a "roller" restraint from one of the automatic-type fixtures. However if you are using shell elements, that might not work (depending on the selection).
          If that does not work, use the "old", tried and true method of applying restraints: Choose the "Advanced" option in Fixtures Property Manager (PM). You can select a reference plane. For example, choose the pipe or flange end face for the restraint, then choose a plane that is parallel to that face. There should be three component directions available to select in the PM. Choose the one that is normal to the plane and put a zero (0) value in there. That will hold the end face of the pipe from translating normal to itself, but will allow radial expansion and translation in the plane.  The symbols should look like 3D arrowheads placed normal to the surface (indicating a restraint in that direction, in this case zero). Hope that helps. -Tony
