after the convert to sheet metal function I try to edit the k factor, but after the change the flat pattern in the drawing doesn't update.
It' remains as the k factor wasn't changed.
Can you try and tell me if this problem is replicable ?
Looks like the "convert to sheet metal" feature plain ignores the K factor, but works well with gauge tables.
I think you could build your own gauge table and use that instead of k factor (on the long run it's more reliable, too)
Hi Federico,
are you sure ?
Try to edit the k-factor in the table and you can see that the flat-pattern doesn't change.
You see difference if you change the bend radius, but the k-factor is the same.
I attached an example part, it's not the real part.
I asked because this command is 3 years old and I thought that was strange this bug that nobody in this 3 years had reported.
I imported a part and used this command, but when I changed the k-factor the flat-pattern didn't changed.
Works ok in SW2010.
Can you post the part to see if the problems there?
Michael
Edit. Dohhh - the file will be in SW2011 so I wouldn't be able to open it
