Does anyone else use or has anyone else attempted to use an indented (top level) BOM with cut list items for weldments?
I have been attemping (since I think SW 2006 or 2007) to use a top level indented BOM with weldment cut lists included.
I have a BOM template created for this task and did some test BOM's on existing projects.
I have noticed that some weldment details are either missing or incorrect sizes.
From what we have figured out, the intented BOM is showing cut list items from the "as machined" version of the weldments.
I have been attemping to work through this with our VAR and SolidWorks and the latest answer that I received back is that I may have to put in an "enhancement request".
How can this be an enhancement request when the BOM is wrong??
Has anyone else tried this and noticed the same thing?
Thank You,
Mark
Hi Mark
I've used weldments with an indented BOM and have come across a lot of problems and then sometimes it works fine.
The main issues that I have found occur when:
inserting a 'standard' part.
Using more than one configuration of a weldment in an assembly.
Mirroring a weldment to as a new part
The problems that I have encountered are:
The wrong length is reported, tends to be with configurations and SW only looks at the active configuration in the part.
The value is not evaluated and I get the expression in the BOM.
Cutlist does not contain values - this tends to be with saved bodies, mirrored etc.
Trying to document these and make sure they occur repeatedly is difficult.
I could avoid these, but then I loose what I would consider to be the advantage of some of the modelling operations available.
So yes I have experienced what you say but I can't offer a general work around as there are different factors to consider. For the sake of the drawing I have sometimes manually overwritten the table but, I don't like doing this.
Would this not be the case of the BOM looking at the configuration used in the assembly? Admittedly this is different from a weldment cutlist which looks at the 'as welded' config.
Roy.
